Topic: AOD Swap (Read 995 times) previous topic - next topic
AOD Swap
Does anyone know where I can find a list of AOD tranmisssions that will swap into my 87 5.0? I can find V-6 AOD's all day long and AOD's out of LTD's etc... Are they all the same?
AOD Swap
You really want a V8 trans,you can get bye with a six if you take it easy on it,If you have a floor shifter a mustang would work.
the lincs are a little longer so you would need to shorten the drive shaft.The LTD I"m not sure.
AOD Swap
UB in Moyock???? Howdy neighbor, I'm just up the road in Chesapeake(near Greenbriar)...
The BIG LTD(Crown Vic) tranny is the same if you need a column shift trans... It's no big deal to swap levers if you get the wrong trans...
Tom
