Topic: PCV Help (Read 910 times) previous topic - next topic
PCV Help
87 Thunderbird Sport Coupe, 5.0 EFI.
WHERE is the PCV located, any body got a photo.
Thanx:hick:
PCV Help
The PCV valve itseft is located in the back center of the lower intake manifold.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
PCV Help
If you change it,also change the crankcase ventilation screen underneath it.They are usually really packed with .You may need a small o-ring removal tool,or something else (needle nose pliers) to pull it out.
PCV Help
Eh, a couple days late...
