Topic: Mustang springs.... (Read 3670 times) previous topic - next topic
Mustang springs....
Will Mustang GT front springs be a direct swap in an '88 Sport?
Mustang springs....
I put mustang GT springs from a 88 into my 87 Thunderbird TC with no problems. Lowered the car slightly too.
:burnout:
Mustang springs....
Thanks a lot.
Mustang springs....
check the tech section on the main page for interchangeability. Shocks and struts are a no go, springs I think are OK
Mustang springs....
Springs aare all I need for now.
Mustang springs....
You can use later Mustang ones in the front. I have stock 95's, with about a coil (and 1/8?) removed. Hard to remember how much, it's been 8 years.
Mustang springs....
The ones I want are for a Fox Stang with a one inch drop.
Mustang springs....
Well, since Foxtang springs are apparently already shorter than our stockers, a lowering spring would likely have a Birdy sing its beak on the pavement.
Mustang springs....
Hmmmmmmmm,I didn't realize that.I wonder how low stok Stang springs would lower my Sport.I only want about an inch.
Mustang springs....
I have cut (1 coil?) 4 cyl Mustang springs in the front of my TC.  Sits nice with 25" skinnies.
Mustang springs....
I don't want to cut any springs.I have fairly wide tires as well.
Mustang springs....
Quote from: MasterBlaster;156546
No, no...they'll be fine.
This is how mine sits with BBK '87-93 Mustang 5.0 lowering coils in front. Actual drop, I dunno, I assume it to be about 1.5". It sits at almost the exact same height as the stockers did with about a coil and a half cut off (if I remember correctly)
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Mustang springs....
I tried stang (H&R 1-1/2") lowering springs in the rear of my 86' T/C and the bump stopshiznits before the springs did. I could still wiggle the springs freely but couldn't pull them out. Then I changed the rear suspension anway.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Mustang springs....
My rear suspension sits right,it's the front I want to drop just a little bit.
Mustang springs....
http://www.partsamerica.com/ProductList.aspx?parttype=59&ptset=A&searchfor=Coil+Spring%2c+Front
Hey Vinnie you can compare them here.I used the cs8602 they dropped me an inch rides great,took a couple of weeks though to settle to that.the cs8658 are stock ones.
