Topic: Im doing a tc rear need swap help!!!! (Read 1283 times) previous topic - next topic
Ok guys i kno i need new cables and stuff but which cables do i need ? the cable that attaches to the pedal, the intermediate spring assembly, and both driver and passenger side cables? Were can i get these? are there any part numbers? also im really lost with the brake lines cause on the cool cats site it says for 83-86, what about 88? unless im reading incorrectly. also where would i need adapters at? and how many?
[SIGPIC][/SIGPIC]5.0 Standard
REBUILT MUSTANG AOD
Magnaflow mustang exhaust
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
Well for the cables read this.
If you read cool cats closely you will see what it says about 87-88s.
New 3/16" and 1/4" Brake Lines
The 1983-86 Cougars have the stock 3/16" brake lines from the master cylinder to the back, along the passenger side framerail. (On 1987-88 cars, the brake lines ran down the driver's side, and you can simply omit this part). Now Turbo Coupes used 1/4" lines in some parts to handle the higher volume of fluid. However, it is very expensive and impractical to replace all your car's brake lines. Therefore, new lines on the rear axle itself will need to be installed. One side will use the 4' section of 3/16" line (driver's side on '83-86), and the other side will use the 14"; piece of 1/4" line. You will also need a 3/16"-to-1/4" adapter for the longer side, where the line enters the junction for the caliper hose. This is because you will use your stock brake junction; one side is 3/16", the other side is 1/4". I would not recommend using brass adapters, as they will not fit correctly and can leak fluid. Steel adapters work best. You can purchase a line bending tool for about $7 or so; that'll help you get the funky bends you need to jump the center section of the axle. If this all sounds sort of strange, don't worry--it'll become clear to you as you attempt to hook up the brake lines
As far as the adapters go I dont know.
Maybe you should try searching for the answer, or wait for someone that has done it.
iv been searching all day lol i just dunt wanna do it the wrong way
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
wat does it mean by omit? throw it away or just use it still?
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
I am not sure because i havent done the swap yet but it seems like you dont need the extra brake line he is talking about.:dunno: I have a 3.73 TC rear waiting to go in after I sandblast and re-undercoat my sport.
Hopefully someone that has done it already will chime in.
