Topic: Clutch in the TC (Read 1771 times) previous topic - next topic
Clutch in the TC
Clutch in the TC
there fairly easy. Just about like any domestic RWD car/truck/suv
Clutch in the TC
Well, I've never owned a stick till now. Hell I've never even seen a 2.3T in person till now. I'll let you gus know. Any recomendations on the brand of which to use?
Clutch in the TC
Quote from: 84 Fila;154758
what do you plan to do with the car?
I had a local clutch shop whip up a little gem the last time i put a clutch in
Clutch in the TC
Ive heard the ram replacement is a good one for the average guy. Its sposed to be around $150 for the kit.
Clutch in the TC
As of now, it's up in the air. I'm figuring out how bad the rust is. If it's savable it's my DD. IF not it's getting humanily parted.
Clutch in the TC
I bought a perfection hytest clutch and it has been in the car for 34,000 and still going stong. That is with the need feathering needed to get the power up on take off.
Clutch in the TC
the only clutch kits we use at the shop are LUK brand. haven't had one fail yet. stay away from the el cheapo brands. they are $h!t. and sorry about the grille i still have it and your name is on it its just things around here go from chaos to mayhem on a daily basis.
louie  :birdsmily:
My famous last words:
Clutch in the TC
Make sure you check what kinda shape the clutch fork is in. The original fork in mine had one of the spring clips at the TO bearing end broke off, but I figured since it had been fine before, should be good now.....nope. Swapped in my new engine with a brand new clutch, and the TO bearing was whining after less than 5000 miles. Had to buy a new clutch fork, which is out of production now.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Clutch in the TC
You have some choices.
The RAM setup that Aerobird runs is nice.  I run the centerforce DF with an aluminum Flywheel.  Also very nice.  Spec Clutches are also very nice, but the 6 puck deals are like an on/off switch, so not very nice for a DD.
88 TC, Lots of Mods.
Clutch in the TC
Nevermind, the car is dead.... parts car
