Topic: Digital dash and H.O swap (Read 2278 times) previous topic - next topic
dont know if there related  my speedo doesnt work
(lights up and displays 0 mph) any ideas?  car is an 87 cougar 5.0 full digi dash
bad vss or chewed up driven gear would be my guess.
1979 Ford Fairmont
[/B]
my guese is if it stoped working all of a suden, it most likely the clip that plugs into the sender on the tranny came undone youmay of had something fly up and knockit off.
I love it when a plan comes together!!!-Hanibal Smith (A-Team)
Quote from: raser13;154393
i just bought the car i have no idea if it worked before
Eh mine works fine:D . Check the VS sensor on the trans. Either it or the gear is messed up. Also if you drive it for a bit the *average speed* part of the trip computer should say something other than 0 mph. That should let you know if you're getting a signal or not.
Quote from: thunderjet302;154460
well the average speed dont work so i guess its a wiring issue or the Vss
i'd still check the clip underneath the car. but it might be the circut tape on the back of the cluster they like to get brittle. kind of like what happened here:
http://www.foxtbirdcougarforums.com/showthread.php?t=14080
Quote from: SLEEPER T-BIRD 87;154526
Yep
FIXED! someone cut the VSS wires at the trans
