Topic: Worst thing to change on your car (besides the heater core). (Read 3567 times) previous topic - next topic
Well mine is the #7 spark plug. Thanks to the funky plug angle on the GT-40P heads it pretty much is right behind the dip stick tube. Thank goodness I have another 29,000 miles before I have to change the plug:hick:
Oil pan on a 5.0, with the oil pump a close second. I'd change 5 heater cores before I'd change another oil pan again.
Yeah my E7 heads have a weird angle too.  Mostly the plugs nearest to the firewall were pains in the A$$, most notably when we went to put my headers in.  But I havent changed enough of my car to really know yet.
A flat tire!
Seriously, I had the donut on the car when I was getting new tires put on. Just sitting in the driveway, it not only looked ridiculous but even though the tire was properly inflated, the weight of the car still made it bulge almost to the point of sitting on the rim itself.
If I ever get a flat in that car, I'm screwed.
Hell the plugs on a 3.8 are worse than a 5.0.  Heater core took me just over 2 hours.  I'd put a water pump above a heater core.  I still haven't replaced the water pump gasket on my car.  I despise the thought of having to pull all the brackets and the pump for a simple gasket with a pinhole leak.
Quote from: EricCoolCats;154256
Amen to that!
3.8 spark plugs are 100% harder to change than 5.0 plugs..  Heater core.. I can do it under an hour.
Hardest part to change on a fox?  ****ing rear control arm bushings.
stop bitching about plugs, ones on my car are worse, i have an airpump, and abs master in the way, i have small arms and i can barely fit them in there!
Quote from: CougarSE;154284
I'll second all that, I did the heater core in my '85 in 40 minutes.  and yeah, good luck getting the bolts out of the stock control arms that have seen ANY winter. :flame:
o boy, i dont like the sound of that im rebuilding front and rear suspension on my lincoln, i take it its a bitch. JOY!!
My 88 bird's 3.8 head gasket...I just won't do it.  An engine swap would be less of a hassle.
1987 TC
The front end of the lincolns are not that bad to work on. The plugs on my 99 expedition are a real pain.
:ford::oldcougar::mercury:
front coil springs
i always have to fight and fight to get those  things in. even 4cyl stang ones!
1979 Ford Fairmont
[/B]
the entire wiring harness....
Quote from: SLEEPER T-BIRD 87;154347
Well that's worse than a plug:giggle:
