Topic: 93 t-bird turbo option (Read 3043 times) previous topic - next topic
in a thread a few days ago i asked if i could put a 302 in a v6 t-bird after getting a few responses i realize it my be to great a under taking so my next ? is what could i do to get some power out of it i happen to get the only wuss version of the car they made for the weight of the car the v6 is not enuff to have any real fun in can the v6 be turboed and if so what path should i look for to find one for the car also supercharger is a option but the one i found for the v6 was 4k seems alittle steep i would do the v8 swap first just wondering any ideas on performance upgrades would be helpful thx again jeff
Re: 93 t-bird turbo option
Well u can turbo the 6 if u so want to.
But like a SC u will need to spend money.
Header for turbo and the turbo and so on and so on for all odds and ends.
Also with stock V6 u have to wonder how long it will last with turbo or SC,
U could just spray the V6 with wet kit and around 75 shot and hope all is well and lasts.
So not mater what u do u will need to spend money.
If u have somewer to do most of the work your self and u are able to do this kind of work u will drop the cost of doing stuff down.
If you want to go to the trouble of turbocharging a V6 (and I do mean "trouble", these engines barely stay together in N/A trim) you'd probably be better off finding a 3.8 SC out of an SC or XR7 (or better yet, a whole parts car). Installing a turbo in the car would be a helluva lotta work because there are no kits available for it - everything would have to be custom. I think somebody makes turbo kits for Mustangs, but they have completely different engine bays.
Actually, unless you've got a deep emotional attachment to the car I would recommend selling it and buying a V8 or SC T-Bird or Cougar. Swapping cars is much easier than swapping engines if you're not knowledgeable. There's more to an engine swap or upgrade than just the engine - you'd need a stronger transmission and an 8.8" pumpkin (V8 or SC cars already have these), plus a lot of wiring.
Quote from: jefflewis1106
Punctuation anyone?  :wtf:
To be perfectly honest, the 3.8 is not worth modifying if your cheap. You could take the same money required to modify a 3.8 V6 and do a V8 swap and you still would be dissappointed with the V6. Now if you are determined to modify the V6, check it Morana Racing they are the authority when it comes to 3.8's including 4.2 strokers, boosted applications, etc. Dont get me wrong, Im sure a 3.8 could be built nice, but not cheap.
If going the cheap route is your main concern, and you want to go fast cheap, then buy a 87-93 fox body notch mustang and enjoy a plethora of aftermarket parts. If being different is your goal, like many on this board, then be prepared to shell out some cash.
1988 Tbird Stock bottom end 306, Windsor Jr's, Explorer intake, 125 shot.
Best ET: 12.11 Best MPH: 113.8 1/4 mile
Try http://www.tccoa.com They know way more about MN-12's then we do. There is one guy who put a turbo on his Thunderbird, his screen name is Sir William.
Quote from: lowcat
yeah, he used a setup where the turbo is actually under the car, somewhere towards the gas tank...
Quote from: Thunder Chicken
right now, there are people developing a turbo kit for the SC's, where you remove the blower, tubing and lower intake, use an N/A intake manifold, and turbo it from there, but i dont knwo where development is on it
as for turboing a 3.8, i wouldnt do it, and im a big fan of the 3.8, it would cost much more than a V8 swap, the turbo alone could be around 600 bucks for your application, then youll need headers made, all the tubing, then all the support items (injectors, MAF, fuel pump etc.)
stick with the V8 swap
Here's a twin turbo 3.8 Mustang......
Twin
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
but also remember, the 99+ V6's are much more stout than our V6's
That Mustang has a real nice setup though!!! :bowdown:  :ies:
definatly, i love how well its hidden
