Topic: It's amazing what...(updated: clear corner pics pg2) (Read 5444 times) previous topic - next topic
yeah after to wet sand it with the 2000 grit paper, dry it well and cear coat it.  For updated pics of my car check out the users rides section ;)
And no there shouldn't be a hole.
I'm still rounding up materials for my headlights. It seems that my right headlight blows up everytime it rains and apparently I have about 2 inches of water in both lights. Any suggestions to getting the broken halogen glass out of the housing?
I don't have a Dremel...
Also for the sanding at what point does the grit of sand paper become "wet sanding paper"? And what would you use other than water for wet sanding? I've heard of a little bit of soap added to the water makes the job easier or is this just for autobody work?
if your lights have that much water in them, they will probably fall apart with a slight tug.no dremel needed. or use a screwdriver between the housing and lens anmd gently twist it to seperate them.
As for the sand paper. use waterproof sand paper, and it ususally starts at 320grit and goes up from there.  add some soap if you are using a bucket but I used a hose and squirted fresh water every little bit.
