Topic: It's amazing what...(updated: clear corner pics pg2) (Read 5445 times) previous topic - next topic
Those turned out mint ron,did you end up croming the insides of the headlamps or is that what was under the yellowness,lol.
Clear corners are much nicer lookin than the orange reflectors.
Thanks guys.
haha, I figured you would like them Chris, that is what alot of sanding can do for these things.  While I had the lens' apart, I took some black vinyl and put on the bottom of the lens' to give it a darker look to it.  turned out really good I think.
Going to be hard to finish the bird myself though, as I got called back to work starting thursday.  I am working my butt off right now triing to finish that dang cowl hood, then I will get the other scoop in it.
Quote from: 1WLD BRD;155275
THAT must be it! I see it now and yes thats what set's it off from just basic clear
I like it!
looks really good!
1979 Ford Fairmont
[/B]
nice work!!
Looks awesome. I need to finish up mine.
Looking good.  Wish I was that close to havin mine look good.
That looks sweet:D
what do you guys use to glue the lense back on ?
I used clear silicone.
, that second pic looks mean as hell.  Great shot.  Love the newly polished lights.  Man your car is quickly becoming badass!
Wow does that ever look bad ass! You've inspired me, I'm gonna go clean mine up today!
What kind of clear coat did you use and how many cans? Also for removing the reflector did you just remove it and not replace it with anything? And what kind of vinyl did you use for the inside of the lights?
Thanks guys, :cool: :o  But wait til the 351 :evilgrin: is in it to call it bad ass, LOL. ;)
I use a can of that high heat engine clear coat by duplicolor, removed the reflector and use 5 year vinyl from a decal shop that I cut myself to fit, from transfers I made.  then siliconed it back together.
When you pull the amber reflector, is there a hole left?
Only in America do we use the word "politics" to describe the process so well: "POLI" in latin meaning "many", "TICS" meaning "bloodsucking creatures".
The clear is for the light after polishing?
