Topic: one more time just for shiznits and giggles (Read 2341 times) previous topic - next topic
ok, sence the struts on 88's are longer than pre 87, how about a sn95 strut? and who was it that said sn95 springs are cool with us? and were ya talking about vert rear springs? some time this month ill be buying springs, and k member. then if i have enough ill get struts so ill be set for CJ.  eather way tho, im in for those adj. lowers so if the rid height is a bit low i can correct it, but id still like to get it close.
Re: one more time just for shiznits and giggles
It was most likley me.  SN-95 struts would work on 87+ cars.  If you're going to lower it, you might as well use 87-93 struts.  Really it's not as much of a big deal as most make it out to be.
The SN-95 vert rear springs are a better match for these cars than the Fox springs.
you wouldn't happen to know the spring rates of those springs.... would yah???
Not off the top of my head, but the load ratings are what I'm refering to....not neccessarily the spring rates.  The spring rates them selves are pretty similar, but the load ratings vary quite a bit.  The load ratings of the SN-95 vert springs are still about 150# lighter per spring than the original Tbird/Cougar ones were (940# vs 775#).  Some of the Fox stuff is even lighter..esp the C Kits....
cool. i was just wondering if they were stiffer that the Bullitt springs. well... the rear springs at least. ^_^
