Topic: Fuel sending unit parts check (Read 1763 times) previous topic - next topic
Anyone know the part # (E###-etc.) for a sending unit for an '87 T-Bird 5.0 with the standard base instrument cluster? I might have run across one but I need to verify the part number. The one listed says E6SZ-9275-B.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
I've got the one from my parts TC out in the garage. Should be the same sender (buttstuffogue fuel gauge). I'll check it out later on
So what's the word, TC?
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
On a hunch I went and got it (NOS sender), and the resistances check out...it's the right one :D
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Man i sure need one of those. Just for your info ford no longer makes them so get them while you can.
Oh, shiznit, sorry Quietleaf - I had forgotten all about that sender. I do tend to forget stuff like that :hick:
