Topic: Seafoam into the Turbo... (Read 2867 times) previous topic - next topic
For the vac system pull of a hose and suck it out of the can. It makes it way back to the intake and gets burned.
Quote from: ipsd;153124
makes sense. are you guy useing the spray can for the vac system of the pour can?
I used the pour can but the spray stuff should work too.
I should have used some on my Sonoma. Had intake gaskets replaced, and the new Dexcool antifreeze completely clogged the intake ports.
Will any vaccum line on the intake work?? Mine is CFI. I could just poor straight down the TB
Yeah...poor it straight down the TB as that is the best place to get it to all cylinders.  On this type setup, pour it fast almost stalling the engine.  Lay off once it starts to choke, then let it sit for 20-30 minutes.  Start it up and....watch.  Then change the oil and check your plugs.
