Topic: How to wire side indicator lights... (Read 3451 times) previous topic - next topic
I saw somewhere a while back where someone had gave the wiring info to hook up the front fender lights to the signal lights for an alternating signal light effect.I want to do this until I get the energy to install the harness and all to have the side lights work as Ford intended them to.
I think this is the thread you are looking for vinnie.
One caveat: That trick ONLY works if you have "194" peanut bulb side markers. 87-88 Birds have large 1157 or 2057-style bulbs. The trick will not work with those.
Now, for how it works - this should explain why trying it with an 1157 will not work:
The alternating turn signal scheme relies on the 194 peanut bulb seeking its ground through the 1157 turn lamp element. Since the 1157 is so much smaller than the 1157 it lights up nearly full brightness. The 1157 element is carrying some current too, but not enough to light it up (the current in a series circuit is limited to what the lowest draw component will carry - in this case the 194 bulb, which is not enough to light up the 1157).
When you turn on a signal light the 1157 no longer has a path to ground - it essentially has two hot wires instead of a hot and ground. It goes out. When the turn signal bulb goes out the path to ground is restored so the light comes on. The process is repeated every time the bulb flashes, which provides the alternating effect.
The problem you'll run into trying this with 1157 side marker bulbs is that the side marker light will now allow enough current to light up both the turn signal and the side marker, but both will be at half brightness. When you turn the signal light on the lights will still alternate, but they will go from both being at half brightness to one being full brightness to both being half, and sic ad nauseum.
I have the larger bulbs.Looks like I may be changing harnesses sooner than I had hoped.
looking at my harness, there is a 2-wire plug that plugs into the dash harness. the wires are: purple w/yellow stripe, and brown w/ white stripe. purple goes to driv side light, and brown goes to pass side. both lights share a common ground.
1979 Ford Fairmont
[/B]
I think all of those side turn indicator lights take a 1156 bulb witch is a single element version of the 1157. So is there a way to and a resistor to one of the same sized bulbs to make the alternating flashing work with 2 of the same style bulbs?  Also would it look weird with the Side light flashing not the Corner light?  Or is there a way to work up all  3 of the lights and make them flash alteranting? Without getting into things that I can't make.
its simple to hook up cornering lamps.
Quote from: CougarSE;153087
ur so bad ass you could eat a rubics cube and shiznit it out solved::shakeass:
Do I need to pull the dash to hook up the cornering lamps?Swapping the harness under the hood is fine,pulling the dash is what makes me want to wait.I've pulled the dash before,and the console,I just didn't want to get into that right now.
Quote from: ipsd;153080
I think all of those side turn indicator lights take a 1156 bulb witch is a single element version of the 1157. So is there a way to and a resistor to one of the same sized bulbs to make the alternating flashing work with 2 of the same style bulbs?  Also would it look weird with the Side light flashing not the Corner light?  Or is there a way to work up all  3 of the lights and make them flash alternating? Without getting into things that I can't make.
The 83-86 models had a 194 bulb. The 87-88 models have an 1157. The 1156 is a "bright" bulb, used only for turn signal and backup light applications. It's too bright for park lights.
Wait... are you talking about the cornering lamps mounted in the front trim on the fender? Those would be 1156's and should not be flashed - they are there to help you see when cornering and are not meant to act as an indicator for other traffic. The light we're talking about (or, at least the light I think we're talking about) is the corner light, up next to the headlight.
Making the 1157 corner light (or even the 1156 cornering lamp) alternate should be no harder than using a relay to power up the bulb and making the relay ground through the turn signal bulb element, same as the 194 trick. Doing so would be more work than installing the proper harness though...
I'm talking about the fender lights.I have the lights,harnesses,and have cut the holes in the fenders (Did a great job as well I must say),and now I need to know how to make them functional.I'm unsure of how to hook them up to make them work as they should.
I kinda thought that you were talking about the lights that are in the fender. I would think that they just get there signal from the turn signal switch before it goes to the Flasher in the fuse box. Hopefully someone else that really knows will chime in.
check to see if you have a grey 2 pin plug next to the headlight harness plug. its about 1" from the fusible links for the alternator.
1979 Ford Fairmont
[/B]
I don't see one.I have a small grey plug and a small black plug that look like a spade clip goes in them.They are not being used.My parts car has this 2 pr0ng plug,but,That's a lot of harness to replace ,which,I don't want to do.I was wondering if the orange turn signal bulbs (like the signals next to the headlight) would work in the cornering lights.Any ideas ?????
the 2 spade clip connectors are for the horns. i couldnt see Ford making another harness just for those lights. it might be taped up under the wire loom. can you snap a pic of the harness currently installed under the battery tray?
1979 Ford Fairmont
[/B]
