Topic: TRX wheel project completed !! (Read 5765 times) previous topic - next topic
Well, I finially got the 460 TC registered and put the TRXs on for a road test. Everything went well.
Wheel vibration was not an issue.
Project successful....now for shorter front A-arms and rear axles.
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
Here is the link to the original thread on this project for those that may have missed it earlier this year:
http://www.foxtbirdcougarforums.com/showthread.php?t=11867
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
looks good
Man that car makes me jealous. Looks great!
wow,very nice..................no tire rub in the rear?
 that looks good. Those are some big meats on the back.
Man, how do you insure all those vehicles?
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Quote from: Quietleaf;152924
He must be rich.
So yeah...can I have in too?  In your drug empire, I mean ;) .
Looks pissed.  Great stance.  Glad everything worked out.
Quote from: 83-88T-Bird Guy;152868
[/IMG]
What are you going to do for rear axles?  I used a set for a Mustang on the rear from superior (31 spline), did away with the ABS and moved the calipers in.  Works great.
Wheels look great.
TED
Wow, they turned out beautifully. I'd love to do that to the original set I have from the '86.
Only 4 are insured. The other 3 are in storage awaiting engine swaps ......460 ????
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Quote from: Cad-T-Bird 500;152952
Wheels look great.
TED
Mustang Fox axles for sure. Should bring the rear in 3/4 in. and then use a 5/16 spacer to put it dead on.
I do get a hair of tire rub when I hit a bump when going too fast. moving the wheel back in 5/16 in. should cure that and let me lower it down a bit.
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Disc Brakes
To get the disc brakes to line up you can remount the brackets on the back side by cutting out a piece and removing the stock brace.  Then use washers between the housing and bracket to get it to line up right.  I think I just used the original washers that were on there.
The center picture is the original mounting and shows the angle bracket.  The third picture shows the chunk I removed.
This was in Jan of 2004, seems like yesterday.
TED
