Topic: EVTM lottery CD give away (Read 31522 times) previous topic - next topic
Reply #225
-145
Pemdas Ftw!
Reply #226
Quote from: V8Demon;156204
-145
Pemdas Ftw!
and the winner is,,,,,,,[COLOR="Red"][SIZE="7"][FONT="Verdana"]V8Demon[/FONT][/SIZE][/COLOR]
pm with addy or email me revised@brier.net
congrads~~~!!!!!!!!!!!!!!!!!
brackets, parenthisis, exponents, multiplication, division, addition, subtraction
This problem came from my math cheet sheet quick reference guide i put together for homeschooling with an explaination.
X=4    Y= -2
-3x – 10(x-y(5-4) + 7) -3
-3x – 10(x-y(1) + 7) -3
-3x – 10(x-(-2)(1) + 7) -3 ** insert -2 for Y but y was negative as well so
              a negative times a negative is a positive
-3x – 10(x+2(1) + 7) -3
-3x – 10(x+2 + 7) -3
-3x – 10(4+2 + 7) -3
-3x – 10(13) -3
-3x – 10(13) -3
-3x – 130 -3
-3(4) – 130 -3
-12– 130 -3  < here is where some people get confused.  When you have a bunch of negative numbers in a row,, you only need to add them up as though it were money you owe.  So,,, you owe 12 then you owe 130 then you owe 3.  No matter how you look at it, your still adding in a negative direction.
Answer :  - 145
The only difficult part of this problem is watching when you first insert the value of Y into the problem.
Reply #227
and now,, back to the lotto......
You have been told that your sluggish starting problem might be caused by a starter relay/solenoid getting worn out or the same for the starter.
you end up installing a new starter relay and suddently your car does not start.  NO click, no crank, no nothing.
you have interior power / radio / headlamps/ instruments ect but no crank.
whats likely to be the problem?
Reply #228
i need addy's from the following members,, please pm
thnx
scott
warbird9
cougarse
V8Demon
Reply #229
You overtightened the two posts on the solenoid, therefore creating internal pressure (warping?) and ruining the new solenoid.
That's my guess... yah, I've done it. :D
Reply #230
Quote from: cougarcragar;156345
:rollin: :rollin: :rollin: :rollin: :rollin:
nope,,
hint,,,
what did you do wrong?  what was the one thing you did not do?
Reply #231
*hint* think of what came off, and whats not there now
Reply #232
The ground cable for the starter motor?
I'm out of ideas. :D
Reply #233
Not quite, but on the right track
Reply #234
ahh,, your getting so much warmer...........
hows about you go out and look at that solenoid real close,
this makes an awsome prank to pull on someone...:hick: :hick:
hint again,, has something to do with the transmission.
Reply #235
*Calmly sits and desk and raises his hand*
Reply #237
*hint* it's a wire that was missed and not re-hooked up. Re-read th question then go look at your car.
Reply #238
rd/blu start signal isnt hooked up
Reply #239
:hick: and the winner is,,,,,,,,,
[COLOR="Red"][SIZE="7"][FONT="Comic Sans MS"]gumby[/FONT][/SIZE][/COLOR]
pm with an addy and ill get you a cd,,,,,,,,,congrads:hick:
