Topic: EVTM lottery CD give away (Read 29399 times) previous topic - next topic
Reply #210
If the answer is what I think it is, calling the '88 "SEFI" is inaccurate :D
Oh, and the shiznitter question is faulty too. Doesn't matter which side of the equator you're on - the water will rotate in whatever direction the toilet is designed to rotate it:
http://www.snopes.com/science/coriolis.asp
Reply #211
Quote from: Thunder Chicken;155713
i know,, i had a problem with that and how to word it. we figured that one out a while back eh? :D  I figured it would leave the answer open to correction and upon dong so, would yield a win
why do i have a feeling this one is a toss out.
Reply #212
got my disc today thanks
Reply #213
Since no one answered yet(and you said it would prob get tossed anyway)... In those systems there are only two injector drivers in each EEC... The CFI fires one inj at a time, while the EFI(not SEFI) fires three at a time, as they are wired parallel groups and not individually(want me to figure the total resistance :D)...
Ford refers to the systems as "bank fire", which is very confusing... What they mean is bank of injectors, not engine bank(right or left)... GM more correctly(OK less confusingly) refers to these systems as "batch fire"...
 BTW the 2.3 turbo uses the same system, as does my '93 Lightning...
Reply #214
Glad that ones gone:hick: thank you tom.
now back to the loto,, i have 6 cd's left so,, for the win,,,,,
Before these.,,,,, there was ..........???
Reply #215
What is it?
Reply #216
it is a device constructed of two back to back diodes which by either arsnic or boron doping process increasing or decreasin the valence electrons available within the K shell of the atom, will define thier being silicon or germnium in construction ,, therefore, within the confins of the depletion region will conduct either via hole or electron flow , EMF.:hick: :hick:
Reply #217
Quote from: jcassity;156017
For a hint... THESE(it's in there some where)...
Now you see what I've been up to when I went missing here and there...
Reply #218
Tubes
Reply #219
Quote from: CougarSE;156092
Tubes
drum roll,,,,,,,,,,,,,,,,,,,,,,,,,,, the winner is...........................
[SIZE="7"][COLOR="Red"][FONT="Book Antiqua"]CougarSE[/FONT][/COLOR][/SIZE]
congrads,,, pm or email me at revised@brier.net with addy:D :D
Reply #220
now back to the lotto:evilgrin: :evilgrin:
solve:
x= 4 ........... y= -2
-3x – 10(x-y(5-4) + 7) -3
anyone remember my dear aunt sally?
Reply #221
i can do that shiznit!!
i went to sylvan im smart!!!
Reply #222
umm, 85?
1979 Ford Fairmont
[/B]
Reply #223
Quote from: 32VFoxBird;156153
umm, 85?
nope,, you can use a calculator you know,,,:D
pay close attention to "Y" in the early stages of this problem or you'll hose it up.
and while we are on the topic,,,
if multipication is just a short cut way to addition,, then why is a negative times a negative , A postive?  thats always bugged me.
Reply #224
hint a subtracting a negitive is like adding a positive
