Topic: help me identify this part, (Read 2260 times) previous topic - next topic
I am stripping engine and parts of a 1983 TC, transplanting motor and am having trouble finding computer.  I just need to retrive parts, get rid of car and figure the engine set-up later. .... One source says under the dash, I found this part to the right of the glove box.
This brochure says what it says,,,,,where is it refering to,
And this one from the same source says....
the computer is in the passenger kick panel, under the dash to the right, pull the kick panel off and there it is! no idea what that part is you have
where was that part located,, those additional pics are not needed as its not the eec.
Also, around the harness, is there a cable tag or ID of any sorts.
with that i can figure it out.
At best, just list all the wire colors for the green connector and i can look it up that way.
scott
Computer is located:
Passanger kick panel. Pull it off and look u, it's right there. Held in by a little plastic holder thing and a ground wire I think.
Quote from: jcassity;151671
scott
The part I have pictured was on the passenger side, behind glove box against fender well, not the fire wall but the fender well, level with the AC ductwork..
wire colors on the green connector brown,red/white stripe, red/blue stripe, white, white/red stripe, blue/red stripe, and a red/green stripe?----hard to make out stripe color of that one.
Ok, so what does it do?
Thanks, you definitely have the mojo on this car.
Thanks so much guys, I was able to locate the parts and remove it.
glad to help!!
Quote from: 84 Fila;151733
warns you when you have a lamp or bulb out by illuminating the Lamp out bulb in the cluster if equipped.:screwy:
How... it's an 83. You said 85& up. Is that like the lights on my idiot panel that say high? and low? beams out
Quote from: 84 Fila;151943
yep,, eggzactly
although i had a brain fart,, its not just 85 and up.  i just remembered how both my 84's were configured on that boring cluster.
