Topic: Digital Dash Coolant Sender (Read 1579 times) previous topic - next topic
What is the correct Coolant Sender to use for the the Full Digital Dash? Does anyone have the part # this part?
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
F2AZ-12A648-A  hope this helps
louie  :birdsmily:
My famous last words:
My wiring harness only has the 1-wire connector. How would I install the 2-wire connector for my full digital cluster?
1988 Thunderbird
check on cool cats. there is a write up on it.
louie  :birdsmily:
Quote from: 88BlueBird;150911
you just ground the black wire and the other one goes where the old wire is.
I love it when a plan comes together!!!-Hanibal Smith (A-Team)
humm,,leme see now,,,,,
wasnt it Tom (turbocoupe50) who a while back mentioned that ,,,,,,,,,,,,
SENDERS wire to the computer
SENSORS generally wire up to the dash
:flame:
terminology is about the same as the correct placement of a decimal point,, makes a big difference.
your sensor has a single wire,, while your sender has two.
Thanks guys. I found a wiring diagram and it appears you are right. The other wire just goes to ground.
1988 Thunderbird
