Topic: Will an AOD fit in my trunk? (Read 2956 times) previous topic - next topic
Just wondering because I'm considering buying an AOD from one of the local recyclers to take home and build up and the Tbird is my only vehicle.  Wanna know if I gotta rent a truck just to take it home :hick:
If you remove the dipstick tube (it twists out), yes. But then you may have trans fluid all over your trunk. So I'd recommend removing your trunk carpeting, and maybe bringing something to plug up the dipstick tube hole.
Hmm.  Any chance the tube will just twist to a horizontal position?
...and bring someone to help you lift it.
Good to know.  Guess I'll bring a shop rag or something to plug the hole.  And maybe wrap the transmission in a garbage bag.
Quote from: Dogcharmer;150547
It's alright.  I'm a certified lunatic ;)
Hope you don't throw your back out dropping that thing into the trunk...
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
I'd be a little more worried about getting back out.  Guess I could always hoist it out with my cherry picker when I get back to the garage.
In or out, either way...if you're doing it yourself, it'll be hard on your back because you have to bend at the waist to set it in there and can't use your legs. I'd say definitely use the cherry picker to get it out, and having someone set it in there for you (hoist or whatever) or at least helping would be a very good idea.
Garrett H.
Exhaust sound clip
Another clip
A transmission will fit with no problem.  Hell I brought a 7.5 axle home in my cougars trunk a long time ago.  thing almost fit all the way in.  only one drum stuck out.
I also hulled a t5 in my trunk once.. that was nothing.
Guess I'll see.  I'm a tall guy and fairly strong, I can usually move large awkward objects a little easier than the guy next to me.
Take a freind with you, make them help, then buy them a beer later
I'm tall and fairly strong too, but I wouldn't try throwing an auto tranny in a trunk by myself unless I was literally throwing it. Really, what do those things weigh?
I would probably even think twice about doing it with a T5 (which is what, 100 lbs?).
It's just so, so hard on your back to bend at the waist and set something that heavy, down that far.
I'm just conscious about my back...my dad threw his out when he was about my age and it bothers him every day. I don't wanna go through that.
BTW I can fit in my trunk with room to spare so they're definitely roomy :)
Garrett H.
Exhaust sound clip
Another clip
Yeah Ive done it alone before.  NO easy task and yes your back will probably hurt for a week afterwards, mine did.  Have somebody help you if possible.
