Topic: FS - custom gauge panel and more (Read 3255 times) previous topic - next topic
*custom aluminum gauge panel fits at the top of the radio bezel. it holds two 2-1/16" gauges. includes white face mech oil pressure gauge and line - $60
*fox washer fluid bottle - $10
*TFI coil bracket - $5
*headlight/dimmer switch panel( 3 pieces) - $10
*650 DP holley main body - $10
*primary and sec metering blocks for above carb(no jets or power valve) - $20
*t-bird grill emblem - $5
*pass side quarter panel t-bird emblem - $5
*t-bird trunk emblem - $5
*DZA1 V8 SD eec - $10
*2 stock lifter hold down trays - $5/ea
*stock steering shaft(minus "bow-tie" looking piece to attach to the rack) - $10
all prices do not include shipping. located in Houston, Texas 77044
leave email addy for pics.
1979 Ford Fairmont
[/B]
Can you make more of those, or only have the one. I can't buy one at the moment, but may be interested in the future. These will fit 85-88, not just 87-88 right. The interior dash face is the same.
I'll take it if it will fit where the AC was in an 84. And can you make more
i didnt make this one. it came with gauges i bought over 2 yrs ago, before i even had a thunderbird.
1979 Ford Fairmont
[/B]
Do you know if it will fit where I asked. Thats what I'm removing so if I can stick guages in there, great
Quote from: 84 Fila;150207
im not sure. maybe someone else would know.
1979 Ford Fairmont
[/B]
Anyone else have an idea on this?
I don't think it'll match exactly, honestly.
bump
1979 Ford Fairmont
[/B]
also have 87-88 TC steering wheel for $15 plus shipping.
1979 Ford Fairmont
[/B]
If I can get a solid yes answer to if it will work I'll take it. But I really don't have cash in hand so...
It says its for an '87-'88, don't call dibs on stuff you don't really intend to buy.
I want to buy, but I need to know if it will fit is the thing. I should have money in the mail tuesday wendsday for it. If it will not fit my 83-84 car Brian, do you want it?
It wont fit an 83-84 car. That goes in place of the cubby hole, or equilizer that you guys dont have provisions for.
I don't, Brian does. His is an 85 which had it doesn't it? Sorry man, I'm out. I really did want it though, my water temp and fuel pressure guages would have looked good in that
