Topic: test (Read 2472 times) previous topic - next topic
test
egr block off plate for a 2.3?
test
A py $20 waste of ^%%&&$%## block off plate from a TF member. He advertised mill-cut 1/4" thick high-carbon plates and sent 1/8" sheet stock with holes that are too small and too close together that was cut by hand. Stupid thing is like $1 worth of materials and looks like he traced an EGR valve and the cut by hand making everything too small. To top it off he sent it in a standard envelope with a 37 cent stamp, so I had to pay 50 cents just to get it from my postman. When confrunted all he said was, "hey, it's only $20". He's the second biggest loser on my list after that @$$ Chuck Haug.
test
you need something made? i have acess to a milling machine for another week till school is out.
test
No, I just put the EGR on upside-down and capped the vacuum.
test
ok figured id offer, id make it for free if you wanted it
test
Have access to at least 1/4" steel? I can send you a template.
test
i believe so, my schools got tons of steel i can use
