Topic: New online part store. (Read 1462 times) previous topic - next topic
http://kalecoauto.com/index.php?main_page=index
Kuhneutson Valve
(AKA "Kneutson, Kanutson") Our superior Kuneutson valves are superior to the inferior kuhneutson valves! For use especially on engines with camshafts. The number one sign of Kuhneutson failure is reduced bore on your engine block! Easily remedy this with a Kuneutson Valve from KaleCoAuto! Now compatible with modern computer controlled cars.
Adjustable Powerband
Wish you had a little more low end torque? Maybe you want a high revving formula1-esque screamer? KaleCoAuto's Adjustable Powerbands are the perfect solution! The power bands are made from titanium-injected rubber, with high grade 440 fasteners. Six links are included. One band is for horsepower, and the other for torque. You may use more than three links per side, but extreme caution should be taken!
Cross Drilled Brake Lines
Want improved braking? Why just cross drill those rotors? Introducing KaleCoAuto cross drilled brake lines! Improved airflow through lines provides superior brake cooling. Brake fluid is exposed to cool moving air, almost instantly reducing heat, and providing shorter stopping distances! All lines are made of quality latex. Brake lines come in: Red and Yellow. Please specify color when ordering!! Warning!! You must replace ALL brake lines at once. You may mix colors.
lol thats funny~!
lol
Were is the flux capacitor? I want a Flux Capacitor!
1987 Cougar XR7 5.0 SOLD
1992 Ranger 4.0
2018 Hyundai Elantra
2019 Ram Rebel
hey where's the freaking long weight... i without them selling a long wait, i question their integrity and their so called "superiority."
Welcome to five years ago.
do they have a dist cap for a 52 henweigh?
louie  :birdsmily:
My famous last words:
whats a henweigh you ask? about 2 lbs.
louie  :birdsmily:
Quote from: xr7cat;150027
its in the "conversions" category. sellin pretty cheap, too.
1979 Ford Fairmont
[/B]
