Topic: trans crossmember (Read 1611 times) previous topic - next topic
trans crossmember
in these next couple day im gonna make my cat dual exhaust. i currently have a single hump crossmember in. and from what ive heard, i need a double cossmember of a mustang. ive gone to two junkyards and neither have any crossmembers from a fox stang. can the single one be modified to where that 1/2 hump is enlarged to be big enough to work? or will that not be safe? i dont wanna build a death trap, but im anxious do have true duals and am running out of places to buy a double hump x-member.
thanks,
keith
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
trans crossmember
My current car had the dual hump from the factory for some odd reason.  My old V6 had the single.  Try looking for V8 87-88 Cats and birds at the yards as well.  You might get lucky.
trans crossmember
Some Cougars and T-Birds had them, some didn't...seems to be no rhyme or reason (gee, there's a shock LOL). A lot of people have run dual exhaust with a single-hump crossmember...it all depends on the size of the pipes (H-, X-, etc.).
trans crossmember
Be careful buying used ones, The connection tubes like to rust from the inside out.  I found out the hard way from one I bought on E-bay. I would suggest just buying a new one from Ford Racing.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
trans crossmember
My '88 Birds,all 3 of them came with the double hump crossmember.Even my V-6 car.
trans crossmember
You can find them on everything from 83 to 88 cars..  My 83 has a double hump.  my 88 v6 car does not..
trans crossmember
i looked at 2 cougars there, and 86 5.0 and a 87 5.0, both had single. if what eric siad is true, i might try just to run the exhaust through that half hump thing. is only 2.5 inch, so its not much bigger then stock. so hopefully everything will work.
