Topic: quad shocks (Read 2398 times) previous topic - next topic
quad shocks
are the mustang and tbird quad shocks the same? i know the brackets mount different. i have a pair from a tc but need to know if they will work on the stang.
86 thunderbird elan
86 mustang coupe
quad shocks
Yep, the axle dampers are the same between cars. In fact, a lot of parts stores will only list the dampers for Mustangs, but they are identical to those used on the T-Bird/Cougar.
quad shocks
Quote from: EricCoolCats;149349
the thunderbird/cougar quads are longer. then the mustang units.
ive swapped bird ones into the stang with no binding but the stang units maybe a hair short for a stock height cougar bird
quad shocks
thanks guys
86 thunderbird elan
86 mustang coupe
quad shocks
That's true sleeper. When I installed my IRS setup, the rear brackets were supposed to line up with the quad shock bracket holes. They didn't come close. When the mustang guys did their swaps, they could reuse those holes.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
quad shocks
That's due to the rear frame rails being different, and the brackets attached to them, AND the distance between the mounting brackes on the rear axles themselves...and all of those have nothing to do with the actual quad shocks. The quads are the same between the cars. You cannot buy a Cougar- or T-Bird-specific quad anymore. They're only listed for Mustangs. And if you do find a store that lists them for our cars (which is a miracle), that shock will cross-reference to a Mustang.
The quad shocks are not under tension like a normal shock. You can push or pull on them to whatever length you need, and they just stay. If binding is an issue...flip the shock around. That usually solves the problem.
quad shocks
I installed Monroe gas matic quad shocks, (32242), on my 87 TC with no problems.
1987 Turbo Coupe, 306, Trick Flow Track Heat heads, Comp Cam, Trick Flow Pistons, Eagle Rods, Center Force clutch, T-5, 8.8 w/373 gears, and a bunch more
quad shocks
I got a set of KYB gas for my dampers, listed for an 85 T-Bird.
1985 Thunderbird TC
2.3l .03 over,Ported and polished Head and E6 Manifold, LA3, T3/T4 Hybrid Turbo, Stinger FMIC, Forge BOV, Full 3" Exhaust, Essy Timing Gears & UDP's, BBK 255lph Fuel Pump, Kirban AFPR, Kirban Short Shifter, K&N Cone, Forced4 VC Vent Kit, PA Performance 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, SFC's [/LEFT]
