Topic: Need traction 7.5 3:73 14" 4 lug 88 t-bird (Read 2129 times) previous topic - next topic
Is it doable to get traction with a combination of tires and suspension on the above setup for 1/4 mile? Any good suggestions?
:bowdown:
How much power & how wide of a tire?
[SIGPIC][/SIGPIC]      STEVE ;)
If it's a factory axle in a turbo coupe, it's an 8.8" rear.
What broke on your 7.5?
Its an lx sport model. 350 ft. lbs. and as wide a tire as I could fit.
As it stands right now I have a GT-40P headed HO with a Comp 266HR cam pushing 320+ft/lbs torque. With 215/70/R14 Uniroyal Tiger Paws and a 3.73 Traction-Lok it has no traction. Anything over 1/4 throttle from a stop results in wheel spin and at least 5 feet if not more of granualted tire. A 215 section tire is about as big as you can go on stock 14" wheels. I'd suggest you step up to at least a 15" wheel with a 225 section tire. That's what I'm going to do at some point. Oh and it'll do the same thing with the A/C on full blast:hick: . I need bigger tires.......
Throw some 235/60/14s on the rear thats what my bird had on it when i got it. It might not stop your traction issue completely but it will help.
will these tires work on the rear 88lx 14"?
Mickey Thompson Indy Profile S/S Tire
G60-14
672-7034
Estimated Metric Equivalent: 255/60-14
Tire Overall Diameter: 25''
Tire Tread Width: 8.0''
Tire Section Width: 10.4''
Wheel Diameter: 14''
Approved Wheel Width: 6.5'' - 8'' - 9''
Tire Weight: 31.0 lbs
Note: Bold type indicates spec measuring wheel width.
All dimensions @ 10psi cold on spec measuring wheel.
Was wondering if these would work on the back of an '88 lx bird with stock 14" rims?
Tia
Mike
Quote from: t.birdsc;158612
G60-14
672-7034
Tia
Mike
there too wide plus there a bias ply tire.
Get some drag radials... Cold my Bird will fry the 245/50/16 Nittos, but get a little heat in them and they bite very well...
I'm going to try the MT DRs, everybody I've talked with really like them...
