Topic: Good 12 Volt Switch (Read 1023 times) previous topic - next topic
Good 12 Volt Switch
Anyone know of a good wire to use as a 12 Volt Switch for the Electric choke of a Carb?
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
Good 12 Volt Switch
anything that is ign hot. when i had my 73 mustang i tied into the regulator excite (gr w/red) or you can come off the coil +.
louie  :birdsmily:
My famous last words:
Good 12 Volt Switch
The "Stator" voltage from the alternator is frequently used for this.
You don't have stator voltage until the engine is running.
You don't want the choke heating up and opening before you get started.
Are you sure it requires 12 volts? The stator voltage is about 7.5 volts.
Good 12 Volt Switch
I've seen most of the electric choke's hooked up to the Stator of the alt like soft touch said. My chilton or haness manual shows it wired up this way.
Good 12 Volt Switch
The S (stator) terminal on your alternator goes to the S terminal on your voltage regulator. The ground side of your dash charge indicator (battery logo light) goes to the "I" terminal on the voltage regulator. When the stator voltage comes up it causes the voltage regulator to open the ground circuit for the light, turning it off.
The light control above is a very low current operation, so I think it is safe to add the choke heater to the stator.
