Topic: 302 HO cam in 88 SO (Read 2558 times) previous topic - next topic
302 HO cam in 88 SO
Hey guys can I run the mustang stock cam in the 88 5.0 Cougar thanks guys lmk.
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
Re: 302 HO cam in 88 SO
Only if you switch to a mustang EEC and rewire the plugs to the HO fireing order. (at a minimum)
The power of the cam will be virtually useless without the mustang heads (or aftermarket), bigger tb and maf, and dual exhaust (min 2 1/4) with stock mustang headers.
Well I will be going carb'd and e7 heads also thanks lmk.
ttt
Would be a good idea to check valve to piston clearance, but many have run the HO cam and E7 heads on a SO short block.. I'd use a good set of aftermarket valve springs, the stock ones are pretty much done by 5300-5500. And you sure wouldn't want a piston tagging a valve due to float.
