Topic: help with emergency brake switch!!! (Read 1213 times) previous topic - next topic
ok so who has replaced one or seen what it looks like?  one of the wires has come out of mine  i believe the light green w red tracer but the wire and terminal itself have come out    i wanna know if i can get to it and if i can pop it back in or do i need to replace the switch..  whats the easiest way to get to it???  thanks ahead of time for all of your help!!!
i have my assembly out of mine right now. the switch itself is white, and has one male connector on it. it is held on with one screw, that you'll need a 7/32 socket for.
1979 Ford Fairmont
[/B]
anyone else!!!  thanks 32v
I have no idea.
sorry badbird
Replaced mine recently. The only place I could find it was at Ford and they had to dig deep. Warning- if the rubber bushing on the pedal stop has broken off releasing the brake will wreck your new switch. Tried it twice before I figured out what caused it.
1987 Turbo Coupe, 306, Trick Flow Track Heat heads, Comp Cam, Trick Flow Pistons, Eagle Rods, Center Force clutch, T-5, 8.8 w/373 gears, and a bunch more
