Topic: exhaust (Read 1463 times) previous topic - next topic
exhaust
ok heres my question. i have the 87 GM police pkg.(grandpa special ordered it called decetive sp). has dual ex. can I use the h-pipe and other stuff? i know i'll probally have to shorten it but the parts are fairley new.It has factory oil aux trans and p/s coolers too.
louie  :birdsmily:
My famous last words:
exhaust
As I recall from the days when I had my own Grand Marquis, I believe a Mustang H-pipe will work with stock (mustang) or aftermarket headers.  Not sure what you can do as far as tailpipes and flowtubes go.
exhaust
I think you misread, I think he wants to use the H pipe off the GM on his Bird. Id personally try to keep the GM as nice as possible, I dont think you see those with police packages often.
exhaust
the gm runs good but looks like hell. pop hit the house a few times with it plus its a nj car and has a good bit of rust. the cars been in the back yard for two years. parked it when we got the turbo. plus for the last couple of months i've been robing parts off it. to fix it up i;d have 5 times what its worth in it. but parting it i can keep 3 cars going i figured pops car can live on that way. really clean low mile gm/cv go for $1200 around here this one is worth $400 max w/ cold a/c. i know its a shame but the body is so beat hence the name battlecruiser. i haven't parted it out too bad though a couple hundred bucks and its roadworthy again. i just can't bring my self to sell it though. it has 11" rear drums 11" disc, oil, aux trans and p/s coolers dual ex. and 5k lb towing capacity with 3.55 posi rear 8.8
louie  :birdsmily:
exhaust
also thinking about putting the 5.0 w/ f.i. in my truck then i'll also have the heaver truck block w/steel crank to build. and maybe get some fuel mileage out of the old f-150 which now has a 302 w/ 500 cfm holley 2 bbl with homemade tv linkage made out of a holley choke cable bracket that works real well.
louie  :birdsmily:
