Topic: Trans Cooler (Read 1604 times) previous topic - next topic
Trans Cooler
A few days ago, my radiator started to leak trans flud from one of the fitings. Always has but now it's getting to almost a steady stream when the car is running insted of a simple drip. Is putting one on as simple as getting one off say a newer stang, cutting the ends/fittings off the car lines and the lines from the doner vehicle, leaving some to work with and then splicing with a rubber hose after mounting the trans cooler? Don't wana really rig it on but do it rite.
Trans Cooler
Im assuming this fitting that threads into the radiator is what you need. You can get them through Latemodel Restoration for $4.95 a piece. I've also seen these fittings at Autozone (don't know if you have one nearby) for a low price as well. It would probably be well worth your time just to slap a new one on.
[SIGPIC][/SIGPIC]http://www.fquick.com/slicksport88
88 Sport - 5.0HO, Mass Air, A9L, 73mm C&L meter, BBK CAI, 255 lph pump, 1.7 roller rockers,Professional Products damper, Chuck W motor mounts, BBK shorties & H-pipe, Flowmaster 40 series, 8.8 rear w/3.27's, 93 Cobra M/C, BAER 13in. drilled/slotted rotors front and back, cobra calipers, Russell braided brake lines front & back, C/C plates, 03cobra rims, 255/40/17 Nitto 555's all around
Trans Cooler
His trans cooler lines also have rubber that someone spliced in between the steel lines right near the radiator.
Trans Cooler
I'm just goint go grab on eof a truck at the JY ( ford trunk of corse) and splice in. Lookin for an oil cooler too, maybe another project
Trans Cooler
What kind of trunk has a transmission cooler??
I got one off a truck, there are two styles.  One is over twice the size of the other..  I got the bigger one.. Have had it for 6 months now but haven't used it.  I am running one off a TC at the moment on the 83.  Going through the radiator and the cooler.
Trans Cooler
Trans cooler? yeah, I got a trans cooler :p 20,000 pound GVWR cooler FTW!!!!! Actually I'm not 100% sure of the GVWR, but I do know it's the biggest cooler this company makes - my father bought it for his Exploder after baking the tranny in it towing a 24 foot travel trailer, the traded the Exploder in after spending $3500 on a new tranny before getting this installed, so he gave it to me.
I've got this one in series with the rad cooler. Fluid comes from the tranny, to the big ass cooler, to the in-rad cooler (to warm fluid back up if big cooler cools it down too much, which it almost certainly does, given that it's designed for 1-ton trucks), and back to the rad.
Trans Cooler
I did the same thing and didn't have to cut up my stock tranny cooler lines either.  The added benefit is it helps with coolant temps a little bit as well.
Trans Cooler
I've got two or three coolers from Explorers around here.I'll eventually get around to installing one.I added it to the list.
