Topic: Progress pics of the engine (Read 2719 times) previous topic - next topic
So I finally got around to snagging an HO out of a Lincoln Mark and got it all torn down. Sent the block and heads out for cleaning and machining. Ordered up a summit rebuild kit along with double roller timing chain,roller rockers (thanks cougarman!) and ARP bolts. So where's the 347 you ask? Oh it's in the near future. Since I got some dough to play with Im going the 302 route first to lay waste to a few imports out at the local track. In the meantime here's some pics of the build in progress. Still need to pull the bird in the garage to pull the old motor so im still slackin there. Oh yeah there's going to be a nice little surprise for the motor when im done but I'll save that for when the time comes. :evilgrin:
[SIGPIC][/SIGPIC]http://www.fquick.com/slicksport88
88 Sport - 5.0HO, Mass Air, A9L, 73mm C&L meter, BBK CAI, 255 lph pump, 1.7 roller rockers,Professional Products damper, Chuck W motor mounts, BBK shorties & H-pipe, Flowmaster 40 series, 8.8 rear w/3.27's, 93 Cobra M/C, BAER 13in. drilled/slotted rotors front and back, cobra calipers, Russell braided brake lines front & back, C/C plates, 03cobra rims, 255/40/17 Nitto 555's all around
More...
And last 3...
Give us a clue on the supprise:beatyoass:
Oooo purdy :D
Black?  How are you going to see oil leaks then? :D
351W in the works
Quote from: bhazard;300566
You got woman'd.
Quote from: tireshredder;146408
Spots on the driveway.;)
If I have oil leaks after putting an engine together, I have no business building one in the first place. :hick:  But seriously the only problems I have ever had with oil leaks was valve cover gaskets or a rear main seal. And to solve the valve cover issue I use the metal frame gaskets with the bonded O-ring in em. Those things kick ass when it comes to no leaks. And the rear main? Well I spend a weekend dropping the tranny putting in a new one. BTW im buttstuff about oil leaks. :beatyoass:
Lookin good,you will love the power differance the ho makes.
As for surprises i'm thinking.....supercharger????
Electric turbocharger?
Quote from: Chuck W;146449
Close! Toro electric leaf blower plugged into my AC inverter in the car. :hick:  ummm no just kidding. reminds me of that streetfire video where they would dyno cars using a leafblower.
Quote from: slicksport88;146441
Those valve cover gaskets are nice, reusable too :)
I got the blue rubber ones from Fel Pro.I love them.The factory style metal/bonded rubber alre also great.It's nice to be able to remove and re-install the valve covers without sealant and new gaskets.Just use them over and over.I also use the one piece oil pan gasket.Another piece I'm glad I bought.
Here's some more updated pics. Installed the oil pan, front cover, water pump, bbk headers, and the chuck w motor mounts. probably do the intake some time this week. enjoy.
