Topic: Getting there... (Read 3319 times) previous topic - next topic
Getting there...
thats the primer I used on the back of my bird by the lights.  I used the high build/scratch filler primer, and kept blocking it out till I was happy and there was no ridge or imperfection anywheres.
Getting there...
I decided to take a sanding block to my car today to see how bad the quarters and rockers are at the bottom, after I saw this thread.  Turns out there's a ton of filler in at least the DS rocker panel at the rear, so I might not invest a whole lot into the body of this car.  Probably DA sand the whole car, use fiberglass filler for the small holes in the front fender and regular 'putty' filler for any other dings, etc, and just blow a coat of flat black paint/primer onto it or something.
Getting there...
Quote from: Thunder Chicken;146143
If you were from around here I'd guess they were the same person, and your uncle too :hick:
*EDIT* I can't believe I wasted my 5,555th post on that :punchballs:
HA-HA! :flip:
