Topic: ported the stock throttle body. (Read 1331 times) previous topic - next topic
The other day my buddy and I found a tiny vaccum leak at the throttle body, (bad gasket).  So since I had to remove it anyways, I decided to do a MM&FF trick and hog out the inside (get rid of that little ledge) and knife edge the butterfly.  According to them they picked up 25cfm with this trick.  I also made my own erg block off plate, since I have no emissions equipement on the car.
Anybody else try this?  It feels like it is a little more responsive to throttle tip in.
Nothing like proven and inexpensive mods!
BTW, I would LOVE to paint my intake and valve covers on my 5.0 the same color as your intake.  It would look nice in a double photo shoot next to my 'Stang.
I'll give it a shot this weekend.I have nothing going on.
hell i need to rip my intake off to replace the valve cover gaskets, maybe ill mess with that!
what color is your upper intake manifold?
1979 Ford Fairmont
[/B]
thanks guys, and by the way it aint paint, it's powdercoated. ;)  dunno what color it is, I bought it that way.  The lower intake was powdercoated a cream color, so I painted it that metalcast blue, same with my block and heads.
i was gonna say it kindda looks like duplicolor metal cast
I find out about this after I put the engine back together.............
Neat though. I'll have to try it when I swap out the intake for something better.
Man that is an OLD hot rodding trick.  Guys use to do it to carbs.  Same concept, just on a fuelie.  I didn't narrow the shaft like MM&FF did though.  just cut off the screws and tightened them down then welded them in and ground it off.
