Topic: Unknown "tining" noise....very confusing (Read 2608 times) previous topic - next topic
make sure it is tight and not loose. How do you check it? crawl under and try and move it.
Public Safety Announcement --  MAKE SURE THE CAR IS OFF --End Public Safety Announcement
Sorry.....couldn't resist!
Thanks Paul, I guess had I have thought I would have added that.
Also dont crawl under a raised car unless it is supported by jackstands, on firm level ground.
Dont stick your fingers in the fan when the engine is running either.
Quote from: 1WLD BRD;146187
Or... on a TC, any time the key's on.  Isn't that what the warning sticker on the electric fans says?
exactly, its just a bit of common sense, along with other things. :rolleyes:
Use a long screwdriver with the big end up to your ear.....Makeshift stethescope.  Use it to try and locate the rattle.  I found out that my starter's front bushing was about toast, and between 2100 to 3000 rpms i got a VERY annoying rattle.  It was the last thing I expected it to be.  I would check that first to eliminate it as a possibility.  Putting the car on a lift is very helpful.  that way the car can be revved by an assistant and eveyone stays safe.
88 TC, Lots of Mods.
