Topic: Fuel lines (Read 1760 times) previous topic - next topic
Fuel lines
looking for the main and return line that runs from the fuel filter to a hard line that goes into the engine compartment. I need the whole thing flex line and hard lines, because they can't be separated. Can be out of a cougar, thunderbird, or mark VII
Fuel lines
You could use this
Seriously if i have to replace a fuel line this is the way i am going. But this is the last time i will bother you about it. Just trying to help.
Fuel lines
119!!!!!!!!!!!!!!!!!! no thanks WAY to much
Fuel lines
I'm not sure what repair part you need but you might be able to fix it with fuel injection hose and clamps.If you can't find the clamps I'll send some to you.
Fuel lines
You might be able to fix it with fuel injection hose and clamps.
I can send you the clamps if you can't find them.
Fuel lines
I know i can get the clamps, its really only a section thats like 3 inches long so maybe i will just do that for now, i mean i need to so i can move it around and stuff,
Fuel lines
what size are the lines?
Fuel lines
so anyone gonna tell me what size lines i need to buy, what kind of fittings, and flareing tool?
Fuel lines
Go son get under the car and measure them!
Fuel lines
Lol !!!!
Fuel lines
Should be 5/16" or 1/4" line. As far as the flare tool goes, I personally have never seen a tool that would put the ridge on the line to plug into the stock plastic line, i know they make one dont know where to get it. If there is a napa near by or another good parts store go ask about a repair kit for the fuel line. See what they have.
The Car-go here can get hard line in sections with the ridge on it. I got an 18" piece to fix my line I know they have longer not sure how long though.
Fuel lines
im not messing with the connections into the nylon lines those sections are good. return is smaller then the main line so i think im gonna bring them in and tell them i need to make new ones of these!
Fuel lines
So how are you going to connect to the stock section then? Rubber hose and clamps? Compression fittings would work well.
Fuel lines
flare the lines and use fittings. I might end up doing a rubber line as a temp situation so i can start the car and move it around, cause im to scared to start it now as risk of fire
