Topic: cage installed (Read 2472 times) previous topic - next topic
cage installed
well its not susp. or steering, but its more along the lines of the subframe connectors for chassis stiffening, so here it is.
its a pretty basic bolt-in kit designed for a notch mustang. the fit is "close enough" and it will serve its purpose. when i get a chance to revise it some, ill add longer door bars and maybe raise them some. iill probly redo the rear bars as well at some point, and extend them thru the package tray into the trunk and pick up the rear subframe rails back there someplace. the main hoop matches the contours of the pillars and roof well, if you dont mind massaging the floor to match the feet of the hoop.
cage installed
 that thing isn't gonna twist at ALL
cage installed
Looks  good!
1987 Cougar XR7 5.0 SOLD
1992 Ranger 4.0
2018 Hyundai Elantra
2019 Ram Rebel
cage installed
That's the same cage I put into the first wife's '83.  I thought at one time though I'd "redesigned" the rear bars and they were available.
Just another one of those things that got lost after I left.
cage installed
is that even legal by IHRA or NHRA standards? ive never seen a rollbar installed like that.
1979 Ford Fairmont
[/B]
cage installed
old habits die hard, its not a "cage" you are correct.
and no, not legal for anything. its a chassis stiffenin device only.
cage installed
ah, okay. do you have a link to where you bought it?
1979 Ford Fairmont
[/B]
cage installed
it is an old KB part. out of buisness, most likley out of production.
cage installed
Quote from: gumby;144408
I drove down the "Alley" last Friday and the psuedo shop (Engineered Performance) is still there with a sign out front.  I didn't drive to the end of the building to see what was going on, but from a couple things I've seen, they're still selling "KB" parts, or at least parts from KB's old jigs and plans....
cage installed
yeah, im workin on the alley again. i drive past every day, haha.
last i heard they werent producing everything, but i dont know what is and what isnt. or what they can build, or what kind of timeframe it would take to get stuff.
