Topic: Strut bushings/spacers? (Read 1588 times) previous topic - next topic
It looks like I might be able to go with an 11" brake conversion (woohoo! :banana:) but I have a question. Is using washers the only way to shim out a strut to a TC spindle or are there spacers/bushings we can use? I was thinking that this should be a common performance part that should work better than washers...
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Some aftermarket struts do come with "official" spacers, which are...
...washers. ;)
There's absolutely nothing wrong with using washers. Once they're trapped between the spindle and strut, they can't go anywhere, so...I don't see what's the hesitation in using them...
If you put the washers on the front side of the spindle can you increase your caster as opposed to the back side of the spindle?
louie  :birdsmily:
My famous last words:
The struts I bought from Ether947 had spacers with 'em - the spacers were rectangular with two holes. Just fancy washers, really...
