Topic: 1983-1984 Cougar Headlight bezels w/ marker lights (Read 922 times) previous topic - next topic
Pair of very nice 83-84 Cougar headlight bezels. One marker light has a tiny chip but it's hard to see.
Part # E3WB-13064-A & E3WB-13052-A
$40  Delivered to Carlisle
tbirdregistry.com
26480
27373
Can deliver to Carlisle
Still available. If anyone needs these let me know I'll bring them along. I also have some other small Cougar and LS emblems.
If you you are looking for any 83-84 TBird stuff PM me and I can check to see what I have stashed away.
tbirdregistry.com
26480
27373
You Cougar guys don't need spares?  Getting harder to find in the junkyards these days and they are just taking up shelf space....
tbirdregistry.com
26480
27373
Those will fit any Bird or Cat from 83 to 86.  Got more of 'em than I need too, but it let's me try different eye makeup on my Birds.  There's absolutely no difference in the headlight doors or front clip for Birds or Cats from 83 to 86.  The only difference until you get to the rear door jambs is the grille.
:birdsmily:
The amber lense is different on the cougars. The T Bird are more laid back. I have a extra set from my sons 83 Bird here and they will not fit my 86 Cougar
The header panel on 83-86 birds and cats are different. This makes the grille and headlight bezels unique to each. These are not interchangeable with birds. I also know this from experience.
CoogarXR : 1985 Cougar XR-7
Quote from: CoogarXR;291577
Exactly... so do I.
I brought these home from the junkyard to compare to the TBird and also found there is a slight difference in the contour of the fender.  Hard to tell unless you test fit. I figured Ford would have used the same fender and headlight dimensions and just changed the style slightly to make them look unique but no.:screwy:
tbirdregistry.com
26480
27373
