Topic: thru floor subframe connector update(not for the weak stomached) (Read 11599 times) previous topic - next topic
b-e-a-utiful day to make some progress on the bird.
cut some steel
cut some holes in the floor pan
swiss cheese the subframe hat channels w/a 3/4" hole saw
lay/beat/massage/fit in the steel
build a piece to connect the front and rear connectors, compound miters are FUN!
so that was todays work so far. started about 9:30 this morning. all thats left is to tack the d.side parts in place, and finish weldin everything up. after my daughter goes to bed, time for more weldin!
:birdsmily:
Nice work !!
You want to come over and do Mine ?
1985 Thunderbird TC
2.3l .03 over,Ported and polished Head and E6 Manifold, LA3, T3/T4 Hybrid Turbo, Stinger FMIC, Forge BOV, Full 3" Exhaust, Essy Timing Gears & UDP's, BBK 255lph Fuel Pump, Kirban AFPR, Kirban Short Shifter, K&N Cone, Forced4 VC Vent Kit, PA Performance 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, SFC's [/LEFT]
 you know what your doing man!
Nice work! :)
Looks like it will be strong as HELL.
 What do you plan on doing with the car?
2"x3" 14 gauge tubing?
1979 Ford Fairmont
[/B]
2x3x.083", yeah.
i think that is 14ga
fastcat, it will be a dual duty track/street car. i plan to autoX and open track it as often as i can get out there.
chri85tc, thanks for the offer, but i think ill pass :D
Great job man, keep it up.
thanks for the compliments guys. it great when a plan works out exactly how you want it. i spent quite a few evenings studying mustang guys SFCs, bottom mount and thru floor. jus like anything else, theres a million different ways you can go about gettin it done.
finally settled on my material and design based on strength, invasiveness, and (relative)ease of installation.
the rear sections are 16" long. only 4.25" sticks out thru the bulkhead into the cabin leavin nearly 12" of material stuffed into the stock rear framerails! the front sections are 40" long and extend all the way forward to the kick-up in the rail that leads to the inner fender structure.
I think now I may have to look at installing mine like yours Gumby. I was going to take the easy way and just weld in the tubes on the underside. Since my Full 3" exhaust hangs so low the SFC's would still be above that.
1985 Thunderbird TC
Nice.  I really like that.  I'm wanting to do something similar to the '84 when I get around to messing with it as I don't plan on putting a cage in that one.
Looks like another nice day today....so I bet there's some welding going on now ;)
Those are some nice connectors!! Like you said, there's a lot of different ways of installing the thru-floor connectors. I've installed some lowers on mine and I'm putting the thru-floor connectors in the very near future (a day or 2). I'm using 1X2 .120 for the lowers, 2X2 .120 for the uppers with .120 for the misc bulkhead plates.
John
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Wow that's really nice. I could use something like that.
Those look very well planned out.  Very good job Gumby.
Nice job. I had to pay someone to do mine....lol. He used 2x3 on my car too, but would have rather had 2x2 now.
Jim
