Topic: Paddle shifter for the aod-e (Read 2496 times) previous topic - next topic
This would be cooler if it would work for the aod
http://www.twistmachine.com/products/
Re: Paddle shifter for the aod-e
Yeah it would, I guess you could always switch transmissions. But then again any transmission switching I do will be to a t-5.
Brian (Ifixyawata) told me you could use paddle shifters with the 4R70W transmissions because they're electronically controlled.
Re: Paddle shifter for the AOD-E
Put a Baumannator TCS on an AOD-E/4R70W and you get ManuTronic; fully manual gear selection.
WkStill on this board (maybe, maybe it's cougarnuts) has a 4R70W in his '84 with the Baumann controller.  I think it was from him I heard about paddle-shifting.
