Topic: Transmission vacuum connection? (Read 1259 times) previous topic - next topic
Did 1984 AODs have any sort of vacuum modulator? I got my T-Bird running this weekend, and it isn't shifting out of 1st gear. I suspect the TV isn't adjusted properly, but I wanted to see if you guys knew of a vacuum connection I'm missing.
Thanks!
-Bill
Nope. Shift points and line pressure are controlled by the TV rod/cable. Their is no vacuum connection/modulator on an AOD.
Mine didn't shift from first either,the tv cable had broke and the tranny burned the clutches.A sad day.
