Topic: Ford HEI Dist. ?'s (Read 1712 times) previous topic - next topic
Ford HEI Dist. ?'s
Just wondering if anyone has used one and if they have how well do they work.  I am in the process of ditching the CFI  and going carb so I am researching parts at this point.
Ford HEI Dist. ?'s
A couple of years ago i done the swap from cfi to carb. I got a points type ford distributor and installed the points eliminator kit from pertronics, it was an easy conversion and still works great.
Ford HEI Dist. ?'s
A user here called Sum_Weirdo (may or may not have the underscore) has an HEI distributor in his car
Ford HEI Dist. ?'s
I may be really off topic or point here, but I have 3 TFI dizzys here and a spair duraspark dizzy. If thats what you need let me know and I'll hook you up.
Ford HEI Dist. ?'s
No,  Don't need going with a MSD pro Billet.
Ford HEI Dist. ?'s
Sounds good. Might be on my todo list here soon
Ford HEI Dist. ?'s
My ears are burning.  I installed a Procomp HEI in my Bird during the engine rebuild.  With some MSD 8.5 MM wires.  It was a simple install, just plunk it in the block and then I connected its power wire to a relay I attached to the firewall.  I triggered the relay with the factory coil wire and routed power directly off the starter relay with some good gauge wire.  Hasn't given me any trouble.
