Topic: 88 TC parts car, PA, $75 (Read 2124 times) previous topic - next topic
Yes, $75.00. Located in zip code 19512. First, the car was converted to a 302 when I bought it. I have been taking pieces off, but it has to go. Look at the pics before you get too excited. I'm sure I could get more money by continuing to part it out, but I have other things that need to get done first.
The first one to contact me via email and pay, gets the car. The car must be gone within two weeks or it has to go to the syard. I will be listing it on other sites, so if you want it, please email me. I can answer questions here.
pics-
http://i12.photobucket.com/albums/a242/thundr306/88%20parts%20car/DSC02536.jpg
http://i12.photobucket.com/albums/a242/thundr306/88%20parts%20car/DSC02541.jpg
http://i12.photobucket.com/albums/a242/thundr306/88%20parts%20car/DSC02540.jpg
http://i12.photobucket.com/albums/a242/thundr306/88%20parts%20car/DSC02539.jpg
http://i12.photobucket.com/albums/a242/thundr306/88%20parts%20car/DSC02538.jpg
http://i12.photobucket.com/albums/a242/thundr306/88%20parts%20car/DSC02537.jpg
http://i12.photobucket.com/albums/a242/thundr306/88%20parts%20car/DSC02542.jpg
email - thundr306@comcast.net
Thanks
Jim
That's a shame that you're not parting it out any more. I could be there in 45-60 mins (Delaware County) as I see several things that I'd like to get my hands on:
- keyless pad on the door
- keyless module behind the rear seat if you have it
- washer fluid bottle if it has the sensor (suspect mine might be leaking)
- the painted black panel on the driver's side door at the b pillar (want to put the keypad in there since I don't have the hole for it in my door)
- at least one of your snowflakes with tire to replace my 14" 20-year-old spare (so if I ever find someone to do the 11" brake conversion for me I'll have a spare that fits it)
- turn signal switch, if it's good
- cruise control switches, as mine are flaky (though replacing the entire steering wheel is tempting if I can find a horn button and get the wheel properly leather-wrapped)
- driver's side locking mechanism, if it's not hard to replace (mine won't open all the way when I use the door handle to get out of the car and I keep getting locked out)
- the steel-brushed console panel you show on your rear seat, if the holes are good (not broken through)
- the thin, hard vacuum hose that goes from the vacuum distribution to the AC that turns it off or on (mine keeps snapping in half and I use a rubber T-square to join the ends together)
- your lighter receptacle (I keep a solar cell on my rear deck plugged into mine 24/7 and I'd like to add a second receptacle for it at the rear of my console)
- The black inner liner of your center console!!! The part where the door latch clips on mine broke off and I had to screw a piece of plastic over it to act as a latch.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
I know that there are plenty of parts left that are usable. Thats why I would like to see the parts end up on other cars. I will let you know.
Jim
ya still got the bird? also how far from Tioga PA in Tioga Co are you? Cuz ill be down the weekend of mothers day so maybe we could work something out possibly.
Got that fox rash again!
-Resident smartass! :ies:
If I had a way to get it, I'd be all over this. There is ALOT I could use
Cougar8775- Tioga is probably 4.5-5hrs from me
84Fila- I know, I really can't believe nobody has jumped on it yet
Jim
well maybe i can take a side trip down to see bout it. and it could be possible that id drag her back to ny with me but idk as of yet. also i may be down next week. so we will see what happens. also before i forget hows the core support floors and trunk floor?
I'd be all over it but I have no way to transport it and no place to keep it. I'd give you $75 for the spindles, discs, calipers and struts, though.
Hell, if you gett 'em off for me I'll give you $150.
The car is going to s on Monday or Tuesday.
Jim
:eek:
Are any of the things on my list left? I could take a ride up 422 tomorrow...
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
I know, but time is up. Most of the things on the list are there. I will pm you my cell number. Give me a call tommorow. Sunday would be a better day.
Thanks again for the opportunity to take a drive up (and it was a good day for it). The console liner was exactly what I needed (though I'll put it in later), and the TC wheel cleaned up real nice. I'll have to hunt down a center cap for it eventually, but eBay is looking to be a total minefield for trying to figure out which cap is the right one. Still, it's not exactly a high priority. I still can't believe no one would take the ride for the glass or the quarter panels, as AFAIK there's nothing wrong with them (and the doors definitely looked serviceable).
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Quote from: Quietleaf;143565
What center cap do you need?
Cap for an '88 snowflake (just one).
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
someone wanna cut those quarterpanels out for me?
1987 TC
