Topic: New item every week, #5 is more 83-86 trim (Read 6681 times) previous topic - next topic
I've made it my personal goal to add at least 1 new item a week to ABM.
There will be a new thead every week, and an update to this one.
Week #5 May 7-13
1985-1986 Thunderbird Turbo Coupe, 1983-1986 Cougar "Blue Max"
Replacement RED vinyl for the "wide" bodyside moldings, 50' roll.
$24.99 SHIPPED per set ($5 off if ordered with anything else except decals).
INSTALL Thread (Chrome version) here: http://www.foxtbirdcougarforums.com/showthread.php?p=141578&posted=1#post141578
I'll take one
Past weeks:
Week #1 April 9-15:
1983-1986 Thunderbird, 1983-1984 TC, 1983-1986 Cougar
Replacement chrome vinyl for the "wide" bodyside moldings, 50' roll.
INSTALL Thread here: http://www.foxtbirdcougarforums.com/showthread.php?p=141578&posted=1#post141578
Week #2 April 16-22:
1987/88 Thunderbird Turbo Coupe Model Kits
100% parts completion guarentee. If your kit is missing any parts, we replace them free.
Original, sealed in factory plastic - $30 plus shipping (8 in stock)
Original, no plastic but 100% complete - $25 plus shipping (3 in stock)
New, sealed in factory plastic - $15 plus shipping (12 in stock)
Week #3 April 23-29:
2.3T Tune-Up Kits
Motorcraft Coil: $49.99
Motorcraft Plug wires: $24.99
NGK TR5 Plugs: $7.99/4 Qty
NGK TR6 Plugs: $7.99/4 Qty (1 heat range colder)
Motorcraft Rotor: $9.99
Motorcraft Cap: $19.99
Motorcraft TFI: $99.99
Motorcraft PIP: $39.99
Motorcraft Air Filter: $8.99
Motorcraft Fuel Filter: $14.99
Week #4 April 30-May 6
Prices do NOT include shipping.
5.0 Tune-Up Parts:
5.0 SO SEFI:
8 NGK Plugs - $15.99
Motorcraft Plug Wires - $47.99
Motorcraft Coil - $49.99
Motorcraft Rotor - $7.99
Motorcraft Cap - $32.99
Motorcraft PIP - $42.99
Motorcraft TFI - $104.99
Motocraft Air Filter - $9.99
Motorcraft Fuel Filter - $12.99
Motorcraft PCV Valve - $7.99
All 87-88 Thunderbird/Cougar INCLUDING Turbo Coupe:
CORRECT NEW Fuel Pump sock - $9.99 (NOT the Mustang one)
NEW Mirror faces - $19.99 EACH (BOTH sides available, should fit 83-86 as well)
1987-1988 Thunderbird Base, LX, and Sport:
NEW Chrome grill - $49.99
NEW Header panel - $199.99
NEW Front bumper cover (polyurethane) - $199.99
1983-1986 Thunderbird Base, elan, FILA, and Turbo Coupe:
NEW Rear bumper cover (polyurethane) - $149.99 (fits Cougar as well)
NEW Chrome Grill - $59.99
NEW Rubber trunk seal - $39.99
1987-1988 Cougar GS, LS, and XR7:
1983-1986 Cougar GS, LS, and XR7:
Week #5 May 7-13
I never had much luck "peeling" the old stuff off mine...
Sure :D
You'll have to wait till tomorrow. I'm not even supposed to be "open" today :P
Off to microeconomics class...
OK, Here we go!
First, use a new #11 X-acto knife to remove the old chrome (this piece took me about 2 minutes).
Then sand the area smooth. The nicer you do this, the better it turns out.
Then CLEAN. Use a nice degreaser, followed by some rubbing alcohol on a rag to promote adhesion.
Then lay out your piece, make it extra long and trim to fit.
Push it down real well, going back and forth. This is a LOT easier with the trim on the car. Use a heat gun/blowdrier at LOW setting or a hot day for maximum wrinkle-free ness.
Trim the edges with the X-Acto.
Polish trim piece with Mother's Back-to-Black and call it done. This whole process and this extremely py trim piece in a cold garage took me 10 minutes start to finish. Doing it on an entire car on a warm day will be about 2 hours and would look amazing.
So there you go, ABM's new product of the week! Also, I've decided to UP the quantity to 50' per set, SAME PRICE! :D
Hey that don't look half bad!
I'll be ordering some of that soon.
Any chance on a similar photo demonstration for the 87-88 trim?
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Sure! :D
Thanks for the kind words. I do try to "develop" a product fully before I release it. I need to do a center console decal install series as well. Hmmm... back to work!!
Yes,the center console decal.I'm interested in seeing that.
Quote from: vinnietbird;139948
X2
I mean,an installation in progress to finished display.I really want one,I have for some time,but,I am very cautious about stickers/vinyl overlays.
