Topic: 2.3L parts, clusters, and more. (Read 1969 times) previous topic - next topic
Im starting to clean up house, and try to fund my next purchases. Pictures can be had if wanted.
-Two sets of brown top injectors. 35#. One set is in good shape, other set needs pintle caps and o-rings. 20+ shipping for good set, 15+ for other.
-Two 85-86 TC gauge clusters. 24psi boost gauge, and no ride control light. 7K rpm tach. 25+ shipping.
***i did check out the clusters, and one needs a lens. Two of the mounting ears are broken, and there is a sticker stuck in the bottom corner. You cant see the broken ears, but the old sticker residue is an eye sore, lowered to 15+ shipping***
-11" brake spindles. Off of an 88 GT. 50+ shipping.
-Two TC throttle bodies. One with sensors, one without. I dont know if the sensors are any good. 15+ shipping for one with sensors, 10+ shipping without.
-A pair of WORKING Electro Illuminescant cougar C-pillar emblems. 40+ shipping for the pair.
-I have 3 Cougar horn centers for the TC style steering wheel. 2 of them are in good shape. One, the spring falls off. A little dab of glue, or a fast hand and itll work no problem. Id like 15+ shipping for the good ones, and 10+ shipping for the "injured" one.
-Rail mounted fuel pressure gauge for 2.3L. 15+shipping
-Two tripminders from a crown vic with pigtail. 15+ shipping. 30+ shipping if you want it converted to fit an 85-87 specs.
*added*
-88 speed density mustang EEC. Has ADS superchip module. 60+ shipping.
-87-88 Turbo Coupe gauge cluster. 25+shipping
-Console tray that goes in place of the floor shifter in a column shift car. 10+shipping.
-Flowtech long tube headers. For a 5.0. Ive never used them, never bolted em into a car, so i cant answer any questions. Google it up. 50+ shipping.
Shoot me a PM or reply if you want pictures.
Forgot to mention that I do accept paypal.
I'd like both sets of injectors for ABM as cores.
I'd like one of the clusters for Layla, maybe. What are the condition and miles on them? I'd like to be as close to original as possible.
One cluster has 126,281, and the other 134,461. There is an article around here on how to change the milage if needs be. Each cluster is in good shape. The lens is clean and relatively scratch free. Only scratches are the swirl marks from cleaning.
i changed the milage without the write up.. its pretty easy.
BUMP
Some stuff added.
What's your PayPal so I can pay for those injectors?
*bippidy bump*
Got pics?  How much to ship to 11735?  I have an idea for these....
Quote from: 88turbo;140080
I might be interested in the long tubes. do you have a part number?
The summit part number is  BIG-12104FLT
Ill see if i still have all the hardware and the reducer cones. Also, flowtech now sells h and x-pipes for these headers. I was going to go that route untill changed my mind on my overall plan.
Quote from: V8Demon
Ill get pics here once i figure out a way to illuminate them. I used a 9v battery to test them, but since the pigtails are short, i need to find a way to keep the 9v there, and take a pic. Ill get it for ya somehow :hick:
Graham: I couldnt find the hardware for the headers, i did find the collector reducers. When i bought em, i didnt get gaskets with him though.
Paul: I got some pics of the emblems, i didnt have enough hands to take a picture with them illuminated, but i did test them with a 9v once again, and they lit, and lit evenly at that. The trim rings are a bit pitted, but you could easily sand em and paint em, or something of that sort if you were so inclined.
I still want the injectors. I don't think I ever got your PayPal (I could be wrong :hick: )
Shawn,
I'll take them.  PM me.
PM sent to both.
Payment sent!
