Topic: 500 caddy swap? (Read 3354 times) previous topic - next topic
500 caddy swap?
wow... that 500 ci t-bird is sick.
500 caddy swap?
Quote from: dudeman351;154907
if you use i believe pre 69 closed chamber heads on a post 70 block w/ open chamber heads you get 12.5:1 compression ratio. had a buddy in h.s. had a 69 deville vert we called the attacilac. he did the head swap on a full option car(read heavy) with an adapter plate and 800 cfm vac secondary holley on 93 pump gas w/outlaw 108 octane booster and ran don't remember exactly it was 20 yrs ago about 14.70 at bithlo (orlando speedworld) before they put in the concrete launch pads. oh i almost forgot it had a lincoln locker rear also.
I tried to run the early heads on a late block and it was not a pretty site (74 to 76 engine, with 68-73 heads give you about 12 to one).  Lots of problems with this and it will not run on pump gas.  But when it did run it was sure nice sounding; rev like a small block with tons of power.  Best to stick to 10 or less compression with these engines or use race gas only.
TED
500 caddy swap?
I love blue gas,But your insane!!
500 caddy swap?
Quote from: bhazard;139340
a 500 cubic inch engine in a fwd car?
For sure, in early 70's the Eledorado (Cadd), and Toronado (Olds) was a FWD with a 501ci, relatively low power and HIGH gaz eater...
BUT the front driveshafts was VERY BIG, but a bit fragile for a 5k over lbs car...
Regards,
Dom.
[SIGPIC][/SIGPIC]1985 Thunderbird 3.8 carbed 57k original, summer car.
1980 Econoline inline 6 300ci 300k, winter/working.
1988 Base Bird finally crushed... RIP.
Dominique,  The Ridiculous, Fordus, crazyous!!!  :birdsmily:
