Topic: 8.8 rear end quad shocks (Read 2781 times) previous topic - next topic
Hey guys i just got a 8.8 rear out of a mustang and it had quad shocks, so my question is should I install them? Will the quad shocks give me more power to the ground and maybe better handling or should I remove them from the diff thanks guys lmk.
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
Re: 8.8 rear end quad shocks
They will help with wheel hop, if you've got all the bracket to bolt them up, use them definetley.
Do you have the brackets on the frame rails? I thought the XR7s only got those?
You cannot use Mustang frame brackets...you must use T-Bird/Cougar brackets. Otherwise, yes, install them if you can. They really help keep the rear end behaving.
Well I dont have the Cougar frame brackets but will look for them in a jy thanks guys for your help.
I've got them on my T-Bird and they seem to help a little.Better than before I put the locker in.The quads keep the rear end from bouncing around so much.I installed new quadshocks,as the used ones were VERY used.
