Topic: cd player help (Read 2350 times) previous topic - next topic
cd player help
i have a cd player for my car and need help puting it in i dont know what wires go to what. my cd player dose not have a illumination wire and dimmer wire and dimmer grond so i need to know where they go?:birdsmily:
88 5.0L aod with duel flowmaster and speedo mod
88 5.0L H.O with 5 speed R.I.P
87 3.8L no trans. geting h.o and 5speed (project never ending thunder) started it as of 8-14-10
96 bronco xl 5.0L 5 speed man4x4
:birdsmily:
cd player help
You need to buy an installation kit at Wal-Mart or Autozone or wherever (if you already haven't).It connects to the wires on the CD player,then just plugs into the factory wiring.Costs about $10.00.I think the blue wire on the back is for the lights on the CD player.It can be hooked to a fuse for the lights.Just an idea.
cd player help
i have the kit i just dont know y it wont work i wired it up and the cd player worked but no sound
:birdsmily:
cd player help
i got the cdplayer to work but i have no sound i looked at my wires and they r good. dose any one know whats rong. i also have the stock eq in the car so i think that is what is not leting it work.
:birdsmily:
cd player help
when i installed my new kenwood, i had to rewire every speakerwire in the car.  ran the rear wires down the right side of the car (under kickpanel under the carpet and then under the back seat.  and then i ran the door speakers covertly and the driver side is the easiest.  get you some wire from autozone, get 2 spols infact, and make yourself an extra arm with a clothes hanger to push through the boots and then at one end of the wire put a loop, that way you can loop the speaker wire around the hanger wire and pull it through the boots in the doors.  its whole day job but in the end, its better wire than in the car already.  i couldnt find anything wrong with the wire already in the car, but this is the only way i could get sound to the speakers.
cd player help
I was lucky.I just wired the stereo up to the adapter plugs and everything worked great.When I pulled the stereo last week from my old driver to install it and my 10 disc changer,it was just plug and play.Are you sure you have everything wired correctly?Double check everything and triple check.One wire can mess you up.
cd player help
Just feel lucky that you have the factory plug. Mine looks like a slasher film after the bad guy is dead and the damage done.
Also did you plug in the ant. my radio would get sound until I did that.
1987 Cougar XR7 5.0 SOLD
1992 Ranger 4.0
2018 Hyundai Elantra
2019 Ram Rebel
cd player help
my adter in my car for the speakers to plug in to from the raido only has 3 wires coming from the plug on the stock harnes i can put some pics of it to show any one :birdsmily:
:birdsmily:
cd player help
http://img261.imageshack.us/my.php?image=dscn6170qy9.jpg
http://img250.imageshack.us/my.php?image=dscn6160kc6.jpg
http://img250.imageshack.us/my.php?image=dscn6163cj4.jpg
http://img250.imageshack.us/my.php?image=dscn6158ky8.jpg
what is this?
:birdsmily:
cd player help
"What is this?"That's the amp for the premium sound.
cd player help
y dont i have the right plugs for it i have the 2 plugs for it it should have 3
:birdsmily:
cd player help
where dose the illumination/dash wire go to. i cant find where it gose to. when i go turn on my dash light the speedo light gose out and the dash dose not come on?
:birdsmily:
cd player help
No promises,but if you're hooking the wire to a fuse,I THINK it's fuse number 13 (5 amp) you want so it'll run off the dash lights when you turn on the headlights.Does that help?
