Topic: Deciphering Fox Axels (Read 85491 times) previous topic - next topic
I propose we work together to attempt to document rear widths in sticky worthy format for future people wanting to do rear axel swaps. There is a wealth of info here but some know it, some don't and others come in that ask it over and over again.
I have created a simple cad drawing of a basic rear assembly with what I consider relative dimensions and we have people out there that have rears laying around where we could get accurate measurements and list them out in the same format. As an example Vinniebirds info here  for Mustang, 85 TC and 88 Bird.
I have a 1984 Mark VII 7.5 Disk Break Rear I can measure out and also a 90 Mustang 8.8 (Mustang rears changed arround 90 something I believe)
I did my dimensions this way as opposed to the bearing to bearing measurement that Vinnie took because I believe the distance from housing  into the bearing race is uniform from housing to housing and this is easyer to measure.
Also have Axel Measurements for both sides of axels because I know the Ranger and Areostar 8.8 axels are not the same from side to side. Most of ours will be the same.
And I know Chuck seems to have most of this in his head, possibly he can help us out.
heres some Info to get things going, Can anybody add or correct any of this? I will edit this post as new info is offered.
Car = TBird/Cougar
Year =1983-1985
Ring Gear = 7.5
A = 61”
B = 54”
C =
D = Same as C
E =
F = Same as E
G = 4 Lug
Car = TBird/Cougar
Year =1986-1988
Ring Gear = 7.5
A = 61”
B = 56”
C =
D = Same as C
E =
F = Same as E
G = 4 Lug
Car = TurboCoup ONLY
Year =1987-1988
Ring Gear = 8.8
A = 61”
B = 54”
C =
D = Same as C
E =
F = Same as E
G = 4 Lug
Car = Mustang
Year =1979-1993
Ring Gear = 7.5/8.8
A = 59.5”
B = 54”
C =
D = Same as C
E =
F = Same as E
G = 4 Lug
Car = Mustang
Year =1994-1998
Ring Gear = 7.5/8.8
A = 61”
B = 54”
C =
D = Same as C
E =
F = Same as E
G = 5 Lug
Car = Mark VII
Year =1984-19??
Ring Gear = 7.5
A = 59.5”
B = 54”
C =
D =
E =
F =
G = 5 Lug
Car = Ranger/Bronco II
Year =1983-1992
Ring Gear = 7.5/8.8
A =
B =
C = 29-5/32"
D =
E =
F =
G = 5 Lug
Car = AreoStar
Year = 1986-1997
Ring Gear = 8.8
A =
B =
C =
D = 29-5/32"
E =
F =
G = 5 Lug
Well no one will read it anyway....but ok.
Firstly, Vinnie's bearing surface measurement is to to the outer  of the housing itself....and that is the proper place to do so.
From bearing surface to bearing surface...
8.8 Mustang rear 54"
7.5 TC rear (1985) 54"
7.5 '88 T-Bird rear 56"
From axle  to axle  (wheel mounting surface)
8.8 Stang rear 59.5"
7.5 TC rear 61"
7.5 '88 Bird rear 61"
I guess I'll have to do this...
Car = TBird/Cougar
Year =1983-1985
Ring Gear = 7.5
A = 61”
B = 54”
C =
D =
E =
F =
G = 4 Lug
Car = TBird/Cougar
Year =1986-1988
Ring Gear = 7.5
A = 61”
B = 56”
C =
D =
E =
F =
G = 4 Lug
Car = TurboCoupe only
Year =1987-1988
Ring Gear = 8.8
A = 61”
B = 54”
C =
D =
E =
F =
G = 4 Lug
Car = Mustang
Year =1979-1993
Ring Gear = 7.5/8.8
A = 59.5”
B = 54”
C =
D =
E =
F =
G = 4 Lug
Car = Mustang
Year =1994-1998
Ring Gear = 7.5/8.8
A = 61”
B = 54”
C =
D =
E =
F =
G = 5 Lug
On the Mk 7's they changed from the larger 11.5" disks in the rear to the 87-88TC type.  Not sure what that meant for axles/housings, etc.  The early ones with the larger brakes are going to be 1" wider overall than the Tbird/Cougars and the SN-95 Mustangs.
I have not measured/compared any 99-04 Mustang rear ends to verify if things changed.
There is no need for Dr and Pass side axle lengths...they are the same.....
My 1984 Mark Rear has (had) the 11.5 vented disk so I will be able to supply that info. I'll try to get the measurments tonight.
One side of the Ranger and Areostar axels will swap with some of these housings.. I belive it is the left side axel. (I added that so we could include that info is somebody just wanted 5 lug swap with same axel leangths)
So for the one's above I was figuring listing them as...
Car = TBird/Cougar
Year =1983-1985
Ring Gear = 7.5
A = 61”
B = 54”
C =
D = Same as C
E =
F = Same as E
G = 4 Lug
You definatly know more about this than I Chuck, and your listing is already more accurate. Are you offering to record the info in your post if we can make measurments and supply you with them?
More Detailed Info...
To keep the stock rear wheel offset and drums, the '83-'92 Ranger/Bronco II Left (driver) side axle (29-5/32") from a 4cyl or 3.0L V-6 with the 7.5" rear end, or '86-'97 Aerostar RIGHT side axles (29-5/32") is what you want. They are the same rear axles, the center section is just on the opposite side when you compare the rear ends. The pumpkins are also off center unlike the Mustangs, so you will have to find two vehicles to pull axles from!
And the link
Updated my chart but double checking where that 29-5/32" for the Ranger and Areostar leangth is measured from.
Quote from: Jim_Miller;138280
Car = TBird/Cougar
Year =1983-1985
Ring Gear = 7.5
A = 61”
B = 54”
C =
D = Same as C
E =
F = Same as E
G = 4 Lug
I can mod my post I suppose.
One thing on the Ranger axles.....yes they will fit in the shorter housings...but unless the axle from the other side of a Ranger rear is 3/4" longer than the one used for the Mustangs....using 2 of them will narrow the rear track on a Tbird....
Tbird axles (ALL..7.5 and 8.8) are 29-7/8"  (or 29.895") from the end of the axle (splined end) to the outer face of the lug ....
They are 29-1/2" to the inside of the lug ....
This measurement is the same for the 94-98 SN-95 Mustang 5-lug axles....
Quote from: Chuck W;138293
If I follow what your saying ...
You wouldn’t want to do that, besides it wouldn’t work.
The Diff in the Ranger/Areostar is offset the axels are Unequal lengths and the other axel wouldn’t fit the Mustang housing. (However it might fit another housing.. 88 Bird possibly?)
However using them in the 8.8 Stang housing gives you a 1.5 inch narrower bolt in 5 lug (correct?)
This is then .750 narrower per side
On my Stock 88 Bird I measure 1.5 inch of wasted clearance on the inside between the wheel well and tire on each side. (yes, I’m using the term “wasted” very loosely there.. but I like to live on the edge sometimes)
I’m hoping to utilize that clearance by having rims with a 6” backspace as oppose to the 5” (as best as I can measure with a tire on) backspace of the original 14” rims.
Now if my rims were a 5” backspace (or somebody else’s were) this 1.5 narrower rear 5 lug set up would be perfect.
Just allows a whole other option.
All this is why I would like a record of all the C,D,E and F Dimensions. What COULD we actually mix and match?
Quote from: Chuck W;138295
Here is where things start to get a bit confusing for me. Thats like the Dim I have for the ranger areostar axels (29-5/32")
Is that Relevant?
Or is end (splined end) to bearing race more important?
On the rear I'm working with for my Bird
the 1984 Mark VII axels Splined end to outer lug  is at LEAST 2" longer than the 4 lug that came out of the 90 mustang rear.
Yet they still fit the housing for the Mustang (there's post on the site here about this someplace)
Not even sure an accurate measurment can be taken for the race area but thats what matters on a axel<-->Housing swap.
Jim, you're making my head hurt....
Using the 29-5/32" Ranger axles in the shorter housing gives the same overall width as the Fox Mustangs... 59.5" .... in 5-lug.  I have no idea what the length of the other side Ranger axle is....The 29-5/32" dimension is from the splined end to the faqce of the lug .....  add .75" to that and you're at approx 29.9"....which is the Tbird/SN-95 axle length.
The Mk7 axles will be .75" + .50" = 1.25" longer than the Fox Mustang axles... Your early Mk7 axle housing is the same width as the Mustang housings...so yes...the longer axles fit in the same housing, even though the resulting overall width is 2.5" wider.
I threw the info into a spreadsheet to make it more manageable.
I might have gotten all the information correct, I might not have...
Spreadsheet
updated 18:30 02/19/2018 Ye olde Griffshp.com is gone
Quote from: JeremyB;138359
I threw the info into a spreadsheet to make it more manageble.
Axle Spreadsheet
Looks right to me.  Glad to see the 99-04 stuff in there too.
I know Jim has an 84 Mk7 axle, which will be the same as my 84 SVO rear I have in the '80 XR-7.
There will probably be more than one Mk7 variation.
Thanks for organizing it better.
Quote from: Chuck W;138304
lol Chuck!, my Dad's been telling me that exact same thing for over 40 years!
If it helps at all let me say I really do appreciate your help and humoring me. Of all the people on this site this would be WAY harder without your help. Seems to all be obvious to you, however confusing for me.
Jeremy, Wow that looks great Thanks!
First the comparison of the two, I think I said 2” difference, I was mistaken a bit.. here they are standing side by side
1990 Mustang Axel
Overall 29-1/4
Tip <-->beginning of machined surface (race) 26-1/4
Tip <-->ending of machined surface (seal) 27-3/4
1984 Mark VII Axel
Overall 30-1/2
Differance is more like 1-1/4
Also
The bearing Begins .750 into the end of the housing
The Backing plate  is 1” in from the actual end of the housing (outer edge of the seal)
The bearing is .625 wide
I will draw this bering area up tomorrow at work to better illustrate it, right now it’s late and I need to get sleep.
Compairing to Jeremy's info from a ford document (pretty reliable source!)
It's saying the mustang axels I measured at Overall 29-1/4 (29.250) are actualy 29.180
I would be measuring .070 longer i think the Keeper grouve and end are much larger than .070 so I'm going to assume my measurment with the tape measure if OFF
you can bet my Mark VII measurment is off about the same.
I have a 0-18" calaper at work but nothing to measure 30" any more accurate than what I have.
